bushing help
bushing help
im taking the bushings out of the rear control arms because i broke a bolt in replacing the shocks. my question is do the bushings need to be pushed in at a shop or can i do it in house??
Re: bushing help (jasonscivic)
No, no specs, You just need to get them in fully. If you're careful, you can use a wide-mouth bench vise Put a dense chunk of wood or something on the bushing side, so you don't mar it as you crank the vise down. Make sure it's line up well before you start cranking too.
That said, it's probably easier to get the bolt out. It'll require 5-6 drill bits, but that's cheaper than a new bushing.
Got Utensils
11
03-10-2004 06:37 PM
