subframe damage
Re: subframe damage (hayabusa160)
Are you referring to item 1?
If you are
Its only 140.49 and it can probably be removed and replaced with normal hand tools. I know on the eg/dc chassis the sub frame bolts on.
If you are
Re: subframe damage (_BEN_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ »</TD></TR><TR><TD CLASS="quote">Are you referring to item 1?
If you are
Its only 140.49 and it can probably be removed and replaced with normal hand tools. I know on the eg/dc chassis the sub frame bolts on. </TD></TR></TABLE>
If it's item 1 I can sell it for 50+shipping
If you are
Re: subframe damage (murtnabila)
it is item #1, why would i be charged so much to have it bent back if it can be replaced for $100 (or even $50 as mentioned)? Is there much difference between replacing it and having it bent back?
Re: subframe damage (pearlblueb16)
Well, thats because it will a LOT of labor to buy a subframe and put it on. I'd still rather have a new subframe then a bent one pulled back out though.
Re: subframe damage (Ajax)
what price difference am i looking at between having it bent back and having a new one put on? The reason its bent is because i hit a curb pretty hard, so maybe the bend isnt that significant?
It's just like when I had to have my door replaced. They were charging me more to remove the door skin from the door skeleton and to replace it with a new door skin when buying a whole new door was much cheaper. Just replace it. Nothing beats new. Almost nothing, in many cases, at least.
I quoted 50+shipping cause I'm taking it off my car I'm parting out. It's 140 new. I would rather replace it over getting old one straightened out. They're charging labor by the hour most likely and probably how long it's gonna take. At first I thought you were talking about the frame not the subframe. Replacing it is pretty much taking bolts off and the replacing them back with the new subframe.
i just talked to the mechanic (hes a honda tuner as well), and he said its too labor intensive to replace. Isnt it just some sort of machine that straightens out the subframe? its an 00 Si.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearlblueb16 »</TD></TR><TR><TD CLASS="quote">i just talked to the mechanic (hes a honda tuner as well), and he said its too labor intensive to replace. Isnt it just some sort of machine that straightens out the subframe? its an 00 Si.</TD></TR></TABLE>
Get a new mechanic.
Get a new mechanic.
the mechanic was talking in terms of price per labor hour. he was saying that its more cost effective to have it bent back, as opposed to buying a new one and putting it on. i obviously want to have a new one installed, but if the difference in price is too much i guess i dont have much of a choice.
ok. so im confused now. I talked to a guy at the honda dealer and he quopted me the whole front engine subframe for $542.52, but i talked to 2 other honda dealerships and they both said around $190. the guy who quoted me $542 is a honda head, so maybe the dudes who quoted me $190 weren't quoting the right price?
ok its NOT a easy thing to just throw the sub frame in there, and it doesn't just bolt in it welds in, and your WHOLE rear suspension ties into that ****, id pay that much to insure it was done correctly
Re: subframe damage (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">ok its NOT a easy thing to just throw the sub frame in there, and it doesn't just bolt in it welds in, and your WHOLE rear suspension ties into that ****, id pay that much to insure it was done correctly</TD></TR></TABLE>
i think they're talking about the front subframe. afaik, it bolts in
Re: subframe damage (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">
i think they're talking about the front subframe. afaik, it bolts in</TD></TR></TABLE>
oooo well
oooo well
