civic headlight conversion..... KIND OF
Hi, I have a honda civic 1996 two door. I wanted to change the headlights one model up to the 98-2000 headlights. I know the fenders and hood are slightly different. I was curious to know if I could change the fenders and the hood on my 96 and have it able to fit the 2000 headlights? I have heard that I will also need to change the bumper too. I dont want to shave off anything to make the headlights fit, I just want to know what I need to replace for it too happen. Thanks in advance.
atma rama
p.s. atmarama108@hotmail.com
atma rama
Re: civic headlight conversion..... KIND OF (atma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atma »</TD></TR><TR><TD CLASS="quote">Hi, I have a honda civic 1996 two door. I wanted to change the headlights one model up to the 98-2000 headlights. I know the fenders and hood are slightly different. I was curious to know if I could change the fenders and the hood on my 96 and have it able to fit the 2000 headlights? I have heard that I will also need to change the bumper too. I dont want to shave off anything to make the headlights fit, I just want to know what I need to replace for it too happen. Thanks in advance.
atma rama
p.s. atmarama108@hotmail.com</TD></TR></TABLE>
I was under the impression that 96-98 was bolt on in between those years and if you wanted to go 99-00 you had to change the whole front end. I could be wrong though
atma rama
Re: civic headlight conversion..... KIND OF (specv5150)
yea i think the 96 to 98 are bolt on...but the 99-00 u need everything differnet...fenders hood bumper...heard u might need radiator support but i think u can use your regular just need to do a lil modification
Re: civic headlight conversion..... KIND OF (SPNFEDEJ)
96- 98 are the same headlights and hood and fender and front bumper
if you want to go to the all clear headlights with no ridges in the turn signal then you need both fenders headlights and front bumper and hood
Re: civic headlight conversion..... KIND OF (BoostFedBrewer)
My bro's 98 came came repaired with a 99 si frontend, and after he lost conciousness (medical reason) and planted his hood into a SUV bumper, he ended up paying $75 per fender, $150 for a urethane bumper, and just got a CF hood (was actually cheaper after you'd color-match it). BTW he works at an body shop. Painting would be extra for the fenders, as would the price for the lights. I was gonna do this to a 96 but I'm just getting a 99 instead
To be honest, I could think of many other things to spend the $600+ on.
ok ok, so if I get two (99 or 2000) fenders,hood,bumper and grill,and the headlights it will fit in perfectly? If this is true, can I do the job myself? is it easy, or do I need some other modification besides the above things to make this thing happen?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atma »</TD></TR><TR><TD CLASS="quote"> ok ok, so if I get two (99 or 2000) fenders,hood,bumper and grill,and the headlights it will fit in perfectly? If this is true, can I do the job myself? is it easy, or do I need some other modification besides the above things to make this thing happen?</TD></TR></TABLE>
Yes. And for the most part it is bolt on depending on if you do the rad support or not. Do a search for 'conversion' and you'll find tons of info. I've seen three threads on this subject today alone.
cool, I did the seach and I found tons of info, but still I have a question. What is a Rad kit? and if I do w/o the Rad kit will it still look clean (like no one can tell that it's a 96?) yea
it bolts on with the hood, fenders, lights, and bumper. no modification to the radiator support.
answered many many times...
https://honda-tech.com/zerothread?id=1153890
https://honda-tech.com/zerothread?id=1151990
https://honda-tech.com/zerothread?id=1159032
https://honda-tech.com/zerothread?id=1124618
https://honda-tech.com/zerothread?id=1119052
https://honda-tech.com/zerothread?id=1051312
https://honda-tech.com/zerothread?id=1002782
https://honda-tech.com/zerothread?id=986848
https://honda-tech.com/zerothread?id=908532
https://honda-tech.com/zerothread?id=923176
https://honda-tech.com/zerothread?id=907291
https://honda-tech.com/zerothread?id=126733
https://honda-tech.com/zerothread?id=847789
https://honda-tech.com/zerothread?id=845158
https://honda-tech.com/zerothread?id=786752
https://honda-tech.com/zerothread?id=772327
https://honda-tech.com/zerothread?id=765821
The sad thing is this is just 2/5 pages for me....
