d-serise oil pan material ?
Old 02-22-2005, 05:24 AM
RACEPAK's Avatar
Default d-serise oil pan material ?
hello everybody
i would like to know what material honda used for the d-serise oil pans ?
aluminum\sheet metal?
best regards moshik galimidi
Old 02-22-2005, 05:50 AM
spoonek9's Avatar
Default Re: d-serise oil pan material ? (RACEPAK)
Both
Old 02-22-2005, 06:02 AM
RACEPAK's Avatar
Default Re: d-serise oil pan material ? (spoonek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonek9 &raquo;</TD></TR><TR><TD CLASS="quote">Both</TD></TR></TABLE>
can you be more specific please ?
Old 02-22-2005, 06:16 AM
Ricey McRicerton's Avatar
What motor do you have? Some were aluminum, some were steel.
On my D16Y7, it was steel.
Old 02-22-2005, 06:21 AM
RACEPAK's Avatar
Default Re: d-serise oil pan material ? (Ricey McRicerton)
i have a D14 fo real
i'm asking this for a friend.... he wanted to know if its the same gasket for the sheet metal and the aluminum?
p.s.
all D-series oil pan gaskets are interchangeable?
Old 02-22-2005, 07:06 AM
monicle's Avatar
on my old hx motor it was a cast aluminum pan
Old 02-22-2005, 07:10 AM
bbarbulo's Avatar
Y7 steel, Y8 and Y5 should be al
as for gaskets, just look at the part #s from slhondaparts.com
b17a1teg
03-30-2011 02:18 PM
sd.coupe
02-19-2006 07:09 PM
JCracer723
06-06-2003 10:37 AM
civickiller
05-17-2003 08:35 AM
Quick Reply: d-serise oil pan material ?
