Buying used rims' and lip has a scuff
I was just wondering what i could do to check if the scuff is detrimental to the performance of the rim. There is a leak in the sidewal of the tire and i'm not sure if it's the seal on the rim or the tire itself
Re: Buying used rims' and lip has a scuff (spicoli)
I'd be very wary about that. You could always take it to a rim shop and have them re-mount the tire. It should only be like 10 bucks.
Re: Buying used rims' and lip has a scuff (Ricey McRicerton)
You need to find out if the leak is a result of the scuff or if there is a hole in the tire. I the rim is not holding air, you would need to get the rim professionally repaired which will cost at least $50 (if you could do it locally, otherwise you have to pay to ship the rim also).
B_Swapped93
04-12-2014 06:51 PM
sniperslayer
09-28-2004 04:10 PM
