D-FUSER
D-FUSER
i was wondering... i want to buy the STR D-FUSER, but i think they're too expensive... i think it's cheaper to just cut holes into my rear bumper... but is there any tools i can use to make the perfect holes and to make it lined up straight???... has anyone done it before... hey a fella out...THANKS
Re: D-FUSER (yangja)
Get a long ruler, draw a straight line across your back bumper. Then use a hole saw to cut through.
Good luck in your quest of 200mph in your Civic.
Re: D-FUSER (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">Get a long ruler, draw a straight line across your back bumper. Then use a hole saw to cut through.
Good luck in your quest of 200mph in your Civic.</TD></TR></TABLE>
where can i get the hole saw at???
Re: D-FUSER (JDMisGOOD)
yeah like the dude above said
get a big ruler
measure on the sides of the bumper and find the middle, then connect the lines though the middle of the bumper so you have a horizontal line goin across the back of your bumper
now find the middle of the bumper, go from there with your holes
goto home depot/lowes or any local hardware store and get the correct bit, they sell bits that go into your drill you can go as small as an inch or up to about 5 inches, they look like sharpe metal circles, prob like 5 bucks
i suggest you tape of the bumper before you drill though
where your going to drill put a layer of masking tape then a layer of duct tape then another layer of masking tape
your paint will not chip if you do it that way
get a big ruler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yangja »</TD></TR><TR><TD CLASS="quote">i was wondering... i want to buy the STR D-FUSER, but i think they're too expensive... i think it's cheaper to just cut holes into my rear bumper... but is there any tools i can use to make the perfect holes and to make it lined up straight???... has anyone done it before... hey a fella out...THANKS </TD></TR></TABLE>
Cutting holes in your bumper does not equal a diffuser. Holes in your bumper and a diffuser are two different things. A diffuser is made up of fins that accelerate air going underneath the car creating a low pressure zone and pulling the car closer to the ground. Holes in your bumper just free up air trapped by the bumper creating aerodynamic turbulance. Something that you will never need and I wouldnt recommend doing.
Re: D-FUSER (Revolver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revolver »</TD></TR><TR><TD CLASS="quote">
Cutting holes in your bumper does not equal a diffuser. Holes in your bumper and a diffuser are two different things. A diffuser is made up of fins that accelerate air going underneath the car creating a low pressure zone and pulling the car closer to the ground. Holes in your bumper just free up air trapped by the bumper creating aerodynamic turbulance. Something that you will never need and I wouldnt recommend doing. </TD></TR></TABLE>
anyone has any thoughts on this???
i am going to have to 2nd that statment. Plus you are going to have that foam underneith the bumper and its going to look like ***. Sometimes DIY is not the way to do things when you cant afford it.
