head swap done....now car wont start
i took a D16y8 head and put it on a d15b7 block....and it started when the headgasket was bad because i messed up and wanted to be cheap....and i changed it using the y8 gasket put everything back on and the timing belt was loose but the car started...and now we put the belt back on tight and car wont start. any one could think why this could be? because i adjusted the cams and everything to TDC and when i turn the key it sounds like i got turbo and something is blowin off kinda smells like gas
Re: (SOHCD16y8)
Check timing both on crank and make sure the distributor is on correctly (not 180 degrees off). Re-check everything is at TDC and you didnt slip a few teeth on the belt or something. Check to make sure you have spark as well.
Re: (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">Check timing both on crank and make sure the distributor is on correctly (not 180 degrees off). Re-check everything is at TDC and you didnt slip a few teeth on the belt or something. Check to make sure you have spark as well.</TD></TR></TABLE>
Make sure all your connections are good on things. Are you throwing any CEL's?
Re: (delslo93)
did u check ur firing order?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo93 »</TD></TR><TR><TD CLASS="quote">
Make sure all your connections are good on things. Are you throwing any CEL's?</TD></TR></TABLE>
Re: (Ignitecivic)
i got spark....theirs fuel goin since i can smell it and im waisting good gas too lol also the timing is correct since we made sure like 5 different times and still no start
Jdbdkid93
15
01-25-2021 05:20 PM
[713]
05-14-2012 03:23 PM
surrealx
07-10-2010 07:52 PM
I turned the crank to check if my timing belt was snapped. Do I have to return everything back to TD
jus2sho
15
10-09-2006 03:26 PM
h46it
05-17-2003 08:26 PM
