99-00 Si Tranny
Don't Trust Anyone
99-00 Si Tranny
Will a '99-'00 Civic Si Tranny bolt right up to a '00 B18? What will I need? Should I do a clutch/flywheel swap before installing?
Re: 99-00 Si Tranny (Silent Bob)
the 00 si tranny will work, I would upgrade the clutch and flywheel since the tranny is being dropped if there is a lot of miles on the old clutch and flywheel. accleration will be quicker w/ si tranny but hwy crusing will be higher in the rpms which will give you a little worse gas milage.
Re: (Silent Bob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silent Bob »</TD></TR><TR><TD CLASS="quote">I believe my lil bro is wanting to do LS/VTEC. Isn't the 00 Si tranny geared the same as the itr?</TD></TR></TABLE>
I thought it was the CTR that it shared similar gearing ratios with.
Darth ModerVader
Re: (Silent Bob)
Yes, the '99-'00 Si and the USDM ITR share identical gear and final drive ratios.
* B A N N E D *
Just know, the B16 tranny will wind up a lot faster, which means if you're going for full on drag 1/4 mile, this'll be the tranny for you (although LSD would be nice, I guess you could upgrade later). If you want a good highway, semi-drag, and all around transmission, get a GSR. Other than that, if you want a nice turbo/economical transmission, get the LS.
94PearlWhiteGsr
10-04-2004 01:26 PM
