over heating
Re: over heating (Kamin)
Check your coolant level.
Check to see if your fan is turning on.
Since you took the thermostat out, if the coolant level is good and your fan is turning on, its probably time for a new radiator.
Re: over heating (Slopoke)
if your radiator good and fill to the proper level... make sure your fan turns on... if the fan doesnt turn on... go check your fuse for your fan... if not check the relay...i had problems like this also... so i recommmend the relay in the fuse box labeled " cooling fan relay"....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">Check your coolant level.
Since you took the thermostat out, if the coolant level is good and your fan is turning on, its probably time for a new radiator.</TD></TR></TABLE>
If the fan is working, check to see if theres air inside the hose, turn on engine, open radiator cap, squeeze the upper and lower hose.
if it still overheat, try flush the radiator. i bet if its stock unit there will be crapload of buildup inside. if it still exist, get a new AL radiator.
Re: over heating (sinister6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister6 »</TD></TR><TR><TD CLASS="quote">
if it still overheat, try flush the radiator. i bet if its stock unit there will be crapload of buildup inside. if it still exist, get a new AL radiator.</TD></TR></TABLE>
that is good too and also u might want to try and check to see if you have enough ground on your engine because my bro had the similiar problem and it work...
FOR SALE
JDM DOHC ZC
complete swap except mounts
asking $700 e-mail me for pix
FOR SALE
JDM DOHC ZC
