Burnout= Worn clutch??
Ok I have a clutchmaster Stage 3 Clutch in my civic and two days ago I did a nice burn out and now my clutch is grabbing right at the end like it is going out. The bitch only has 3000 miles on it. Any ideas?
Re: Burnout= Worn clutch?? (H22siCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22siCivic »</TD></TR><TR><TD CLASS="quote">Ok I have a clutchmaster Stage 3 Clutch in my civic and two days ago I did a nice burn out and now my clutch is grabbing right at the end like it is going out. The bitch only has 3000 miles on it. Any ideas?</TD></TR></TABLE>
are you sure your tires were smoking and not your clutch? Doesn't normally happen unless you don't break in the clutch correctly, but it does happen. Heard a story a while back about this happening to a twin disk clutch.
Re: Burnout= Worn clutch?? (94_HATCH)
*Nelson Voice* Ha Ha.
But in all seriousness, if you didnt break it in properly you can really fk it if your not careful.
Re: Burnout= Worn clutch?? (cnyej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">did you properly break in the clutch?</TD></TR></TABLE>
Clutch was not slammed or raced at all for 2500 miles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeef84 »</TD></TR><TR><TD CLASS="quote">Stg3? Idk man, are you running a stock or aftermarket flywheel?</TD></TR></TABLE>
Clutchmaster flywheel also *** i am just going to get a act stage 2 Ive always hated clutchmaster anyway. I got the clutch for like $100 brand new
Dnt do burnouts. But was the clutch installed properly?Flywheel resurfaced?
And you are positive that you were doing a burnout and not a clutch out?
Re: Burnout= Worn clutch?? (biotech0123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biotech0123 »</TD></TR><TR><TD CLASS="quote">that sort of scares the hell out of me because I just bought a stg3 with a fly</TD></TR></TABLE>
dont be scared, this dude just messed up his clutch, its not the clutch quaultity.
Re: Burnout= Worn clutch?? (sohcvtec1995)
I was definately doing a burnout. The flywheel and clutch kinda made some noices like they were grinding against eachother. And for the past couple of weeks the clutch has been ground a little bit considering second gear syncro going bad.
ok...the clutch does rub against the flywheel, it's actually mounted to it. That is how the transmission is engaged and disengaged.
I think your clutch is just fucked.
JDM_EH2
09-10-2005 11:34 PM
dohcdelsol
14
08-16-2004 10:42 AM
