Please help me with swap of a GSR into an EK. ***Searched***
I am helping a friend swap a 98 DX EK HB. We are planning on swapping in a GSR motor 0BD2 I believe. I have both cars whole. What do I need to do this swap?
hoses?
Motor mounts?
I think I know the wiring but any info is greatly apreatiated?
P/S?
A/c?
I have waspped EF's but not EK's. Please any info would be good( unless it's negative info)
Thank you
hoses?
Motor mounts?
P/S?
A/c?
Thank you
Re: Please help me with swap of a GSR into an EK. ***Searched*** (Karterguy13)
You will need the upper block mount off of a 99-00 si civic, the rear goose neck off of a 99-00 si, and in order to keep ac (if the hatch has it stock) you need the driver side lower torque mount off of a 94-95 vtec del sol. This will allow you to use the single cam ac pump on a b series motor swap. Use a stock 96-98 ex wiring harness. You will have to cut and extend some wires. If you need anything else just let me know.
Re: Please help me with swap of a GSR into an EK. ***Searched*** (Reiketsukan)
Do we need to worry about the PS on this car? By the way thanks for the reply.
You can use the ps pump that comes on the swap. Your ps line will hook up to the b series pump. If by chance the line does not hook up to the pump you will just need to get a pump off of a si civic.
jdmjeff
06-20-2014 10:58 AM
Tom123456
12-14-2006 01:11 PM
EK SQUAD 425
03-24-2006 06:45 PM
