Comp Cams 59300
Comp Cams 59300
I have a 95 ex D16Z6 with I/H/E I want to put in a Comp Cam 59300 with Titanium springs and retainers, as well as a new Skunk2 cam gear, and Vtec controller. Should I reseat the valves and put in new gaskets at a machine shop or can I just put everything in the head the way it is now?
Also has anyone see or heard good hp results from this mod?
Thanks
Thanks
Re: Comp Cams 59300 (95_SOHC)
it is up to you to go that far with your head, but if you do u might as well PAndP it. and there are good gains with proper tuning.
If you are going to do the compressor trick or some such thing to replace springs and retainers and keep stock valves, I wouldnt worry about much now. But if you are going to have the head pulled to replace stuff, its probably in your best interest to at least have the seats hand lapped at least, and putting fresh gaskets in the head cant hurt anything either.
Re: Comp Cams 59300 (drip pan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drip pan »</TD></TR><TR><TD CLASS="quote">Might as well rebuild the head. I have the 59300 and I love it, it makes more noise than stock... but its not too bad.</TD></TR></TABLE>
did u keep the stock valves and retainers ?
Wilky
09-13-2004 02:18 PM
