help plz....gray smoke comin out of exhuast!!
Alright, I finally finished up my 5spd conversion. Im having no CEL codes. But last night when I drove it, gray smoke kept comin out of my exhuast. I was told that this is normal bcuz I havent driven my car for 7 months and should go away soon. Well, I let it idle for a long time and driven it for 30 min. Gray smoke kept comin out and Im not gettin any CEL's. Also, I noticed that the engine temp was above normal. I filled up my radiator coolant and also the reservoir after I flushed it when I swapped my intake manifold last week. So that cant be the problem. Also, after it idles for awhile (900ish RPM), my RPM just dropped dramattically down to 200ish then goes back up to 900ish. Oh and I recently changed my oil and spark plugs this past weekend. What could be wrong with my car and how could I fix this problem? Thanks in advance people.
Re: help plz....gray smoke comin out of exhuast!! (civictildeath)
I was told my o2 could be bad also. Ill check it out later tonight or tomorrow. I know its not a non-functional CEL though.
Re: help plz....gray smoke comin out of exhuast!! (akad3mikz)
Also I found that my radiator fan isnt spinning. I started my car up again this morning and reved it a few times. Found that black stuff was comin out of my exhuast. What could be the problem with my car?
* B A N N E D *
Are you burning any oil? Also, check your timing to ensure it's correct. You might have a blown seal? As someone else mentioned, check your sensors and see if their is any foiling of the plugs etc. Sounds like you're running too rich to me; but that's just a guess!
Re: help plz....gray smoke comin out of exhuast!! (bb4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4 »</TD></TR><TR><TD CLASS="quote">blown head gasket? need more info</TD></TR></TABLE>
Re: help plz....gray smoke comin out of exhuast!! (vtec y0)
well earlier today when I revved it a few times, it smelled like i was burning oil or somethin, but damn it stinked.
MyVtec8yourV8
07-09-2013 03:16 AM
Red00SI
05-10-2002 01:20 PM
