Too many options
Too many options
So, I have a 94 Delsol Si that needs some work. I have $4k to put into it but I can't decided on what I want to do.
Right now, I'm leaning towards a LS+ Turbo Swap. At the same time, I'm thinking I might want to build & turbo the D16z6 in it already.
I'm looking for a fun daily driver w/ some fun on the weekends, mostly Drag.
I would like to be putting out around crank 250hp Reliable.
Well Lets see what everyone's got... I'm open to other options too.
Here is the Setup....
D16 RBlock Stage 3: Exospeed $2,121.00
D16 RHead Stage 1: Exospeed $735.00
Custom Turbo setup $500
Assemby $600.00
Modified by Pure_Rapture at 11:51 AM 3/1/2005
Assemby $600.00
1 Post
Re: Too many options (Pure_Rapture)
there are endless things you can do....searching will help you find out more opnions
if you have 4k to spend, then your ls turbo is a good idea, but you may not want to use all of your budget, so turboing the z6 is a good option also...you can get 250whp from both set ups and still be ultra reliable
I'd put the money into the z6...
you should be able to get those numbers w/o a problem with 4k.
There was someone on here selling b16 rods modified to take some JDM toyota forged pistons that will fit in the Z6 and support upto like 18psi I think... I don't have the thread here... but I do at home ... I'll try to put a link up.
Re: (Pure_Rapture)
As far as that goes it's all in how you build it. A guy I worked with at Honda in MD, had a built Z6-T , it was his daily driver. Just keep up on it, and everything should b fine.
Re: (Bcuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bcuz »</TD></TR><TR><TD CLASS="quote">As far as that goes it's all in how you build it. A guy I worked with at Honda in MD, had a built Z6-T , it was his daily driver. Just keep up on it, and everything should b fine.</TD></TR></TABLE>
Did he beat on it, or did he baby the **** out of it all the time?
i have to agree with those who said to turbo your d series motor. with the money you have left over you can put it in some nice suspension pieces interior whatever you want
1 Post
Rapture, feel free to contact us or pm me your number so I can call you. I'll be glad to work out a plan for your setup to achieve your goal.
Wil
Wil
1 Post
Re: (Pure_Rapture)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pure_Rapture »</TD></TR><TR><TD CLASS="quote">I know I would be able to pull more power out of the LS, but would a built motor be more reliable then a stock.
Is the Built Z6-T more reliablity then a Stock LS-T @ 250hp???
it just depends on how you build and tune it...if you do it right then yes, if you do it wrong then lots of bad stuff can happen....and a tuned and built z6-t can be reliable at 15 psi all day
krysted9354
06-14-2009 04:30 PM
