High quality pads
High quality pads
I got some Brembo Cross Drilled rotors and I want some new (stock sized) break pads. I need the pads of the front and back of a 1994 Honda Civic Si (Hatchback).
Give me some pics, links, or something.
Re: High quality pads (boostedegcpe)
Re: High quality pads (saxqtzk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saxqtzk »</TD></TR><TR><TD CLASS="quote">http://www.tirerack.com</TD></TR></TABLE>
Re: High quality pads (ineedaswap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ineedaswap »</TD></TR><TR><TD CLASS="quote">my friend has hawk pads and brembo rotors and he says they eat the rotors</TD></TR></TABLE>
I take it that's a bad combination then.
Brembo makes stock sized pads correct?
Re: (Bunz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bunz »</TD></TR><TR><TD CLASS="quote">oem</TD></TR></TABLE>
Don't pads get better than that though?
Re: (EgRedSi)
I've had great results with axxis pads. good performance, doesn't eat up/warp my rotors, inexpensive too. I wouldn't get real aggressive pads if you use cross-drilled rotors
I've had Hawk pads on my car for a year now with no problems. My rotors are Powerslot (Brembo blank with slots CNCed into them) and have seen regular track duty and 45K of DD. I'm replacing them soon becuase I had a locked caliper and it cooked the pad and warped the rotor before I noticed it. Even with it dragging, the rotors show barely any wear at all.
I would suggest Brembo blanks, with PBR/Axxis Ultimates. If you're hitting the track look into Hawk, Carbotech etc. ImportRP has good prices on these in the sponsors section, I've orded from him quite a few times, and have always treated me well.
OEM brake components suck and are overpriced. My Mom warped hers on grocery getter duty after just a few months. Pure crap.
Re: High quality pads (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer »</TD></TR><TR><TD CLASS="quote">I would suggest Brembo blanks, with PBR/Axxis Ultimates</TD></TR></TABLE>
this is what I run, except I use the PBR/Axxis midrange pad (metal master?) instead of the ultimates. I couldn't be more pleased.
Re: High quality pads (dreamer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreamer »</TD></TR><TR><TD CLASS="quote">
this is what I run, except I use the PBR/Axxis midrange pad (metal master?) instead of the ultimates. I couldn't be more pleased.</TD></TR></TABLE>
My car is set up more for touring, I should go with the same set up anyway?
Mikes2000civicsi
10
01-14-2007 04:35 AM
hans stoner
05-09-2004 05:58 PM
Doeboy
10
09-18-2003 09:57 AM
