I need help......ASAP....
hey guys i have a quick question for anyone that knows how i can fix this problem. today i was installing my new power carbon fibre mirrors on my 93 civic si hatch. i started with the driver side mirror. got it mounted and wires pluged in. i turned the key to accessories and the power adjustment worked but whenever i pushed the up or down adjustment the mirror would do the opposite (left and right was ok). i turned the key to the off position and switched the wires....but the same thing happened. anyways now none of the power mirror adjusment works at all....not even on the stock mirrors. also the blower for the heat/ac does not work either. does anyone kno off hand wat i messed up and how i can fix this?
Thanx in advance.
Jim
Thanx in advance.
Jim
Re: (coupe_hybrid)
its not the blower. everything was working fine before i went to install my new mirrors. the mirror adjustment button doesnt work....and neither does the blower as a result of my mistake while tryin to install the new mirrors. anyone else have any ideas about what i screwed up here?
thanx guys
thanx guys
Re: (LS95eg)
i used a voltage tester and tested both sides of each fuse. they are all good. it has to be something else. a relay mayb? i dunno im stumped and really want to get this problem solved so i can use my mirrors and put my car back together.
Thanx for all the input so far guys.
datssoled
07-30-2009 09:54 AM
djsire
08-30-2007 10:15 AM
