about to do fuel light in EG
ok guys, I put in a GSR cluster in my EG and now going to try to get the Low level fuel light and door open lights to work. I tried doing a search but came up with nothing. I am sure its the same as doing it as if you had the JDM SIR cluster which also has a light for low fuel.
Is there anyone that is on here that can give me any tips or point me in the right direction? If not then I will figure it out myself.
I guess I have to get the sender unit from a integra (DC2) or I can go look my *** off for a JDM Civic unit. Thats all that I know so far.
If the actual car itself is not equiped with a low fuel light, then you obviosuly wont be able to make one, but assuming you do, you pretty much had to do a DIY for it in the cluster, meaning you need to find a wiring diagram, and find which wire triggers the actual light to come on when the fuel level gets low and wire it yourself.
As for your dome light functiopning correctly, make sure you have the switch on it set to the idle position ( usually center means ON when doors open and OFF when doors closed)
Also check your fuses, could be them, and also it is not uncommon to have the actual switch in the door jam ( the small rubber button) to go bad and not function correctly.
Re: (97Ej6mike)
search harder, I have read how-tos that said "including the fuel light and other things that doesn't work fix"
I saw it just this week even in someones signature.
