HELP! Sister's EK running bad with swap
Hey guys. I'm posting on behalf of my sister. She has 00 ek. Her motor blew and she replaced the motor with a used one. The motor is running bad she says and has the check engine light on now. (I dont have a problem with check engine light racing but if it is sour then i do) anyway, she did the paperclip test thing and its the zero code. What is that exactly?
Thanks
Thanks
Re: HELP! Sister's EK running bad with swap (3vilMonkey!)
hmm..haynes book of god says this...
(1)
primary heated o2 sensor circuit low voltage...
or primary heated o2 sensor circuit high voltage...
(1)
Re: HELP! Sister's EK running bad with swap (b16delteg)
either that or you don't have the jumper connected properly...does it continually turn off and then turn on or does it do it just once ?
Re: HELP! Sister's EK running bad with swap (Prod)
jumper....i hadn't known she was using a jumper..i thought she threw the same engine she had in it...ethier way...same deal with obd1 and 2...
bjaeyang
19
04-07-2003 05:28 PM
