compression is low in #1 cylinder, should i get a new motor
this is my daily and i communte about 80 miles a day to school/work. the motor is a d16y7 with 192k. the test was 155 180 180 175. are those numbers ok, or should i throw a new longblock in there. i already have a teh tranny off casue im puttin a new clutch in
thanks in advance
thanks in advance
Ya dont even worry about that too much, that is still good compression numbers for that much mileage.. Try pooring a little oil couple table spoons in low cylinder and then do it again and see if it goes up.!
Also make sure you have injectors unplugged and you have car @ full throttle when starting it.
Re: compression is low in #1 cylinder, should i get a new motor (c1civic)
screw rebuilding, get piston rings for 20 bucks and get a oil pan gasket and some thread lock, you'll be good as new
Former Moderator
Re: (flood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood »</TD></TR><TR><TD CLASS="quote">Run it till you notice a large decrease in power, or a crapload of smoke. YOu never know it might run for another 150k miles like that.</TD></TR></TABLE>
That's what I'd do.
And when it finally goes, just find another engine and drop it in. It might cost you $250.00 or so and IMO it's easier to swap an entire engine rather than rebuild one.
That's what I'd do.
1 Post
Re: (B18C5-EH2)
or just replace the head gasket now instead of running the car in the ground, blowing it, getting towed, new longblock.. shrug thats what 400-500, head gasket and studs are 120... takes all of what 3 hours for a noob to swap a head gasket
Re: (B18C5-EH2)
1. Cracked head. 2. Blown piston 3. Cracked Block 4. Blown head gasket 5. Broken valve component - spring, cracked seat, bent valve, bad lifter any of these could be your problem
Re: (flood)
dude chances are the exhaust valve has too much **** around it and needs to be cleaned. run a leak down test your best bet to see what it really is. but that compression isnt too bad. just run it till it blows up and get a swap thats what i did.
Re: (flood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood »</TD></TR><TR><TD CLASS="quote">Run it till you notice a large decrease in power, or a crapload of smoke. You never know it might run for another 150k miles like that.</TD></TR></TABLE>
That may sound ghetto, but atleast it might give you a few more months to save up some money and what not. Just NO racing
i already ahve the tranny off, should i go ahead and swap or should it run for a while, doesnt leak or burn anythign, seems to run fine, they tranny just got replaced due some nice grinding of second gear
Re: (Lanceuppercut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lanceuppercut »</TD></TR><TR><TD CLASS="quote">1. Cracked head. 2. Blown piston 3. Cracked Block 4. Blown head gasket 5. Broken valve component - spring, cracked seat, bent valve, bad lifter any of these could be your problem</TD></TR></TABLE>
how would u know? last night u wanted to turn off vtec cuz it was tooo loud and u didnt even know what mods u have cuz the kid u bought it from said its far from factory
mynameizstitch
20
02-14-2010 09:55 AM
bleebdat
10-08-2002 03:52 AM
