cell code error
Old Apr 11, 2005 | 03:00 PM
smokeydc2's Avatar
Default cell code error
hi all but my delsol is throwing a cell after i changed head gasket it just a continious slow flash any ideas anyone
Old Apr 11, 2005 | 03:13 PM
Oren's Avatar
Default Re: cell code error (smokeydc2)
If you've already jumped it, so that the Check Engine Light(CEL) flashes, count the number of long flashes and the number of short flashes. Then come back and tell us what code you're throwing.
I.E.
3 Long plus 1 short would be 31
4 Long plus 3 short would be 43
Old Apr 13, 2005 | 09:53 AM
smokeydc2's Avatar
Default Re: cell code error (Oren)
well they are all short flashes i normally know most codes but this one got me confused it flahses constant slow flashes with no pauses
Old Apr 13, 2005 | 10:16 AM
EE_Chris's Avatar
Usually if the CEL flashes while the engine is running, it means its misfiring.
When you put the timing belt back on, did you use a timing light to make sure timing was in spec?
Old Apr 13, 2005 | 10:37 AM
smokeydc2's Avatar
Default Re: cell code error (EE_Chris)
cell is only flashing when 2 pins are conected and just with ignition on (car not runing)
Old Apr 13, 2005 | 11:03 AM
Oren's Avatar
try swapping with a known good ecu
Old Apr 13, 2005 | 11:06 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
That could be a code 1, which i believe would be your o2 sensor.
Old Apr 13, 2005 | 11:12 AM
smokeydc2's Avatar
Default Re: cell code error (JDM_Ej)
already changed the o2 sensor . and ecu is good
GsrVtec
Oct 19, 2006 07:33 AM
egcivicb16
Apr 9, 2006 09:02 PM
ls00722
Sep 15, 2005 11:23 AM
Bh8teen
Aug 31, 2005 09:26 PM
hughesl
May 13, 2004 05:27 PM
