Are 96-00 LCAs interchangable?
Old 05-14-2005, 06:20 AM
motion's Avatar
Default Are 96-00 LCAs interchangable?
I recently got in a accident involving a bowling ball sized rock. I was going 45 late Wednesdsay evening, glanced down at my cell, then looked up and saw something in the middle of the street, by the time i figured out what it was, I was too late to out manuever it.. it scrapped my lip and hit the outside of my rim putting a huge dent on it. Theres a huge hole in my side wall.. ******* sucks.. I bent my front driver side LCA.. here are the pics.. (yes I know my car is dirty, its been raining nonstop for 2 weeks here)
Poor lip..
Anyone selling one Si rim?
Here you can see the wheel pushed back just a little bit..
Are 96-00 Civic front LCAs interchangable? If they are, I'm gonna go to a junk yard later this week. I need to get these parts asap as this is my only form of transportation.
I would also like to give a big **** U to the shitface that left that rock there..
Old 05-14-2005, 06:27 AM
swifty4u's Avatar
Default Re: Are 96-00 LCAs interchangable? (motion)
I'm pretty sure they are interchangeable..sucks about that though.
Old 05-14-2005, 06:59 AM
HitEm'Up's Avatar
Yep should be Sorry bout the car bro
Old 05-14-2005, 08:20 AM
monicle's Avatar
yes they are. I have 99 from ex lcas on my 96 dx hatch.
Old 05-14-2005, 08:47 AM
As long as I dont have to take out any more Metal Gears
rukawa1one's Avatar
No they are not! The 99-00 SI have a different sway bar mounting points than the 96-00 EX, and the 96-00 DX- which have NO sway bar mounting points. The SI also has a different fork then the rest.
Old 05-14-2005, 10:05 AM
dsmfan95's Avatar
Default Re: Are 96-00 LCAs interchangable? (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">No they are not! The 99-00 SI have a different sway bar mounting points than the 96-00 EX, and the 96-00 DX- which have NO sway bar mounting points. </TD></TR></TABLE>
I thought all Civics had the same front sway bar.
Old 05-14-2005, 10:09 AM
xhatchracerx's Avatar
Default Re: Are 96-00 LCAs interchangable? (dsmfan95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">No they are not! The 99-00 SI have a different sway bar mounting points than the 96-00 EX, and the 96-00 DX- which have NO sway bar mounting points. The SI also has a different fork then the rest.</TD></TR></TABLE>
he is absolutely correct
Old 05-14-2005, 10:11 AM
rukawa1one's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsmfan95 &raquo;</TD></TR><TR><TD CLASS="quote">
I thought all Civics had the same front sway bar.</TD></TR></TABLE>
No they don't. I know the SI uses a 26mm sway bar with a ball joint type endlinks, EX and LX uses a slightly smaller one with ruber bushing type endlinks, but I'm not sure of the exact diameter. The way these bars mount onto the LCA is different.
Old 05-14-2005, 10:14 AM
haccord2.2's Avatar
Yeah they are interchangeable if you have a CX/DX/LX/HX/EX but the Si ones are different for the sway bar mounts. Also I had a friend that had almost the same thing happen as you and it didn't bend the LCA because they are pretty strong, but it bent his front sub-frame instead. Just thought I should put this out there just to make sure that is what it is. Good luck that sucks that happen, I hate stuff laying in the road.
Old 05-14-2005, 10:17 AM
haccord2.2's Avatar
No they don't. I know the SI uses a 26mm sway bar with a ball joint type endlinks, EX and LX uses a slightly smaller one with ruber bushing type endlinks, but I'm not sure of the exact diameter. The way these bars mount onto the LCA is different.</TD></TR></TABLE>
EX and LX uses the same 22mm sway bar, with the different endlinks.
Old 05-14-2005, 10:24 AM
rukawa1one's Avatar
Default Re: Are 96-00 LCAs interchangable? (haccord2.2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haccord2.2 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah they are interchangeable if you have a CX/DX/LX/HX/EX but the Si ones are different for the sway bar mounts. Also I had a friend that had almost the same thing happen as you and it didn't bend the LCA because they are pretty strong, but it bent his front sub-frame instead. Just thought I should put this out there just to make sure that is what it is. Good luck that sucks that happen, I hate stuff laying in the road.</TD></TR></TABLE>
Ya that's right, they are all interchangable because the chassis is the same from 96-00. But i'm just saying this to the original poster...If u have an SI, just get another SI LCA. U wont be happy if u get an EX LCA and find out it wont fit ur swaybar.
Old 05-16-2005, 02:29 PM
motion's Avatar
Thanks for the replies. Does anyone know the part# for the driver side LCA?
Stillapfg
11-29-2009 12:47 PM
Bull
10
12-23-2007 05:43 PM
R-81DC2
Northeast (Sales)
05-04-2007 03:17 PM
Quick Reply: Are 96-00 LCAs interchangable?
