Oil pressure gauge install
Re: Oil pressure gauge install (kingmonkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingmonkey »</TD></TR><TR><TD CLASS="quote">Your stock sensor should be right above the oil filter. I would t it off or you may end up throwing a cel. </TD></TR></TABLE>
Stock oil pressure sender is seriously junk....I ran with mine straight disconnected w/o any problems at all. It's just a dummy light. I believe it is a pressure switch, and that at 5 psi or less it allows the electricity to ground out on the block, thus completing the circuit and giving you the low oil pressure light on the gauge cluster. I don't think the ECU uses it as input.
RACEPAK
10-24-2005 04:23 PM
