OBD-1 Conversion Harness
Electrician
To place an older, OBD-1 engine into a newer, OBD-2 vehicle. Makes it easier to run the ECU and all the proper harnesses without doing a hack job and installing Algerian Engineering.
Re: (CoupeVtec2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoupeVtec2k »</TD></TR><TR><TD CLASS="quote">so your obd2 wires can plug into an obd1 ecu</TD></TR></TABLE>
Basically OBD2 ECU's are "unchippable" for lack of a better word. You get a OBD1 conversion harness to run a P28 or other OBD1 ECU to give you control
Mr. Indecisive
Re: (specv5150)
or say u have an obd1 b16, if u put that in an obd2 car u can use the 99-00si ecu n ur car will still read as n obd2 engine, n u may even be able to pass inspection
Mr. Indecisive
Re: (chile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chile »</TD></TR><TR><TD CLASS="quote">in the same boat here...would the conversion affect smogging it in a year?</TD></TR></TABLE>
putting an older engine in a newer car will cause u to fail
if putting an older engine into a new car jus get the ecu for the gen of your car instead of converting back for example:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoupeVtec2k »</TD></TR><TR><TD CLASS="quote">or say u have an obd1 b16, if u put that in an obd2 car u can use the 99-00si ecu n ur car will still read as n obd2 engine, n u may even be able to pass inspection </TD></TR></TABLE>
Civic98KH
03-11-2007 09:21 PM
Gmedalion
07-10-2002 07:56 AM
