climate control help
yeah, i wanted amber lighting for my climate control (96-98). so i took out the bulbs, painted them, put them back in, pluged everything back in, and they dont light up.
no, the little wires on the bottom of the bulb are not covered in paint.
no, the bulbs arent bad
no, a fuse isnt blown
no, the dimmer switch isnt turned all the way down
i cant figure out why they wont light up..... they worked fine before i took em out.
anyone have any ideas?
Re: climate control help (Bcuz)
nah, its not thick at all...
before i put everything back together, i checked to see if the lights work...and they dont light up at all....
What kind of car, cuz. You know believe it or not, if try disconnecting and reconnecting your harnesses, it will sometimes make it work. I know this sounds completely retarded. One day I did an odyssey trans., it threw a code for no sensor ouput shaft reading. Pulled it out and put it back and it worked. Sorry for such a long *** reply but it helps to double check.
97 civic
ya ive disconnected, and connected the harness like 4 times, still nothin...
thanks for your help btw...
king29
12-04-2008 03:21 PM
Midori Green
10-27-2008 07:24 PM
cutelilvi3tboig
11-04-2004 09:25 PM
