changing brake pads
Re: changing brake pads (northkai3)
just make sure u have a breaker bar or a guy cuz some of those bolts are on there freakin tight if its a virgin bolt. or u can spray some pb blaster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by northkai3 »</TD></TR><TR><TD CLASS="quote">drums or rotors</TD></TR></TABLE>
just to let u know... on the drums they are called shoes... so most likely she is refering to the disc brakes... however if u are talking about drums.. shoes are a little more complicated
if its brake pads.. its easy except for the bolts, they are tight... so if u can get a breaker bar on them u should have no problem.. it takes about 20 mins per side if ur working alone
good luck
good luck
Re: changing brake pads (93ejay1)
or use a clamp or a jack to push pull the ratchet/wrench to loosen the 2 bolts on the back of the caliper thats the ghetto way i dont have a breaker so whatever works
also there are certain chemicals u will need especially if u want to clean ur brakes calipers rotors and what not ull need lock tight, anti seize, quiet brake stuff, and brake cleaner
ok...well i got my brake pads changed last night i started about 10 and didnt get finished until around 1 in the morning. i bled them and everything and theyre still kinda spongey when i go out and test my brakes. whats wrong?
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">give them time and they will get stiffer and if they dont then u either still got air in the lines or you have a bad master cylinder</TD></TR></TABLE>Sounds like there is still air in the line.
Re: changing brake pads (HondaFanatic708)
u dont have to change ur brake fluid when u change pads but since u did im sure u know how to bleed and adjust them right?
i didnt change the brake fluid...i just bled them since when i first put in the new pads they seemed kinda spongey still. im going to try to bleed them again. so that should be it? it kinda scares me. having to press way harder than before to actually brake.
Re: changing brake pads (jaealdana)
I have noticed extra effort in breaking with my car. It's time for me to change my pads, but I am just to lazy. One good thing is that my calipers have the one bolt design. It does make it easier and faster. Why would you need lock tight? I have never used thread locking compound on my bolt's on the caliper. Should I use some or is it just overkill? Get the disc break quiet stuff, because without anti-seeze or brake quite it will make noise and make lot's of it.
Re: changing brake pads (Bond)
the lock tight is just reassurance ive heard of many people with calipers that fell off bc the bolts came loose. ut ive only had a problem like this once b4 but it was with my shift linkage i had just put on a short shifter and the main bolt came loose and my linkage fell to the floor since then when i fixed it i used lock tight
ive heard of rumors that u have to bleed each wheel of air seperately but the only car ive ever bled the lines on was my bros 3000gt and it didnt seem like we needed to do everywheel but we did and when we were done his brakes were really tight i just changed my pads a week ago and im noticing week brakes so im gonna change the fluid and bleed each wheel tonight i will let u guys know whether or not that changes anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by northkai3 »</TD></TR><TR><TD CLASS="quote">ive heard of rumors that u have to bleed each wheel of air seperately but the only car ive ever bled the lines on was my bros 3000gt and it didnt seem like we needed to do everywheel but we did and when we were done his brakes were really tight i just changed my pads a week ago and im noticing week brakes so im gonna change the fluid and bleed each wheel tonight i will let u guys know whether or not that changes anything</TD></TR></TABLE>
You have to bleed each one seperatly from front to back or so I have heard. Not sure though.
i bled my two front tires...the ones that i changed. the fluid seemed kind of dirty, does that matter...does it effect the way my brakes work? i think ill give it a while for the brakes to tighten and if they dont i guess i will just bleed them again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaealdana »</TD></TR><TR><TD CLASS="quote">i bled my two front tires...the ones that i changed. the fluid seemed kind of dirty, does that matter...does it effect the way my brakes work? i think ill give it a while for the brakes to tighten and if they dont i guess i will just bleed them again</TD></TR></TABLE>
You should flush the lines. It's like bleeding, but you keep doing it until clean fluid runs out. Also, when bleeding, are you keeping the tubing line you're using submerged in a cup with fluid in it? You can suck some air back in if you don't.
When just changing pads, you don't need to bleed the brakes.
erikiksaz1
11-17-2005 03:04 PM
