how hard is it to take out a eg dash?
Old 07-28-2005, 10:38 PM
spoonInspired's Avatar
Default how hard is it to take out a eg dash?
just wondern how hard it is to pull a dash, mine is grey, want to go with black... hit me up... peace
Old 07-28-2005, 10:40 PM
red-eg6's Avatar
Default Re: how hard is it to take out a eg dash? (SpoonHatch94cx)
not to hard was easy to gut my friends
Old 07-29-2005, 02:59 AM
BlueIntegraBoy's Avatar
6 bolts you need to remove:
1. 2 under the side dash covers
2. 1 near the hood latch
3. 1 behind glove box on the right
4. 1 under the top vent
5. 1 behind ashtray console
Parts that need to be removed:
1. Glove box
2. Panel above driver's leg + metal plate thingy
3. Radio
4. Ashtray console
5. Drop the steering column
Wiring harnesses:
1. Remove the three plugs from the fuse box to make dash removal easier
2. Disconnect the two climate control plugs from behind the ashtray console
Now pull your dash out. You'll have a cluster/dash switches and climate control subharnesses that are going to be removed from your dash and placed onto the new dash if you didn't get the subharnesses. Installation is just backwards. Took a friend and me 20 mins to remove his dash.
Old 07-29-2005, 03:04 AM
I am a (Trial User) Army
litterbox's Avatar
Default Re: how hard is it to take out a eg dash? (BlueIntegraBoy)
Ya, I've removed my dash so many times it literally takes 10mintues.
With two people, you'll be done in 20-30 min cause it's your first time.
Dropping your steering column is 4 bolts. Not as bad as it may seem.
Old 07-29-2005, 03:53 AM
HT Order of Merit
JDM_Ej's Avatar
Default Re: how hard is it to take out a eg dash? (litterbox)
Cake.
Old 07-29-2005, 06:53 AM
b204dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Ya, I've removed my dash so many times it literally takes 10mintues.
Dropping your steering column is 4 bolts. Not as bad as it may seem.</TD></TR></TABLE>
i think the hardest part is people forget the bracket litter ! -
FLA$HY_5SiX2
11-07-2011 04:49 PM
ej6hatchie
Paint and Body
05-14-2008 09:48 AM
y2kferari
03-16-2007 02:12 PM
HybridGSR1
06-20-2003 05:31 AM
bbmoto
05-22-2002 12:13 AM
Quick Reply: how hard is it to take out a eg dash?
