OBD1 B18A from 1992 Integra into a EG hatch. Can i use DA mounts and axles??
Sorry, I should know this but i dont.
Can i use the stock DA mounts? or just some of them? and can i use DA axles too?? Or do i need DC mounts and axles?
Thanks!
Thanks!
Re: OBD1 B18A from 1992 Integra into a EG hatch. Can i use DA mounts and axles?? (dek1mfk)
I think you may be able to use the axles, but I am almsot postivie you can't use the mounts. Please don't take that as gospel truth though...I'm not really up on DA stuff.
Re: (JdMdA90)
Look into my signature.
I have done this swap and you CAN use the stock DA axles but you need to use the intermediate shaft.
as for the mounts. you CANNOT use the civic mounts or the top civic tranny mount. WONT LINE UP!!
You will need to buy a custom mount from a shop (ex: http://www.jdmshit.com) to bolt on the top of the tranny. IF you try to use the 1994 Integra Top Tranny mount, the motor will sit on an small angle and that will cause you to pop the axle out when under pressure. The rest you need from a 1994+ integra. You need the drive side bracket/mount and you need the rear bracket. The stock mount works in this case for the rear.
Any questions let me know, I've done this swap recently and there is a lot of wrong info on the net
pigeonnn
07-28-2011 12:10 PM
B16A3Civic*Eg
05-22-2006 10:23 PM
E36 Guy
03-30-2006 10:08 AM
