power steering n ecu help???
im swapping in a 97 ls in my 92 dx hatch, i wanted to kno if i want to keep power steering can i use the same pump from my civic on the ls motor or wat bracket do i need or pump?? also it doesnt come with a ecu will the car run wit the civic ecu?? or shud i wait to get a ls ecu?? thanks
assuming you have a manual transmission...you'll want to find an Integra LS ECU. part number 37820-P75-A0X, x being 0, 1 or 2. You probably have a P06 in there now - 37820-P06-A00. Regarding the part numbers, make sure the middle number in the "A0X" is a 0 and not a 5. A "5" is for Auto Tranny. I've also seen an auto ecu referred to as "L51". You could socket and chip the P06 to run an LS, but it would need to be dyno tuned for optimal performance. I would not recommend using your stock ECU to run the LS. I'm not sure about the power steering. I would imagine you must use the LS bracket though. Hope that helps.
