Are ITR driveshafts compatible with Si???
I have a b16a2 and bought a Type r b18c5 drive shaft, will it fit???
I thought they were the same part number.
Re: Are ITR driveshafts compatible with Si??? (supaman111)
um... I think that the passanger side si the same, but the drivers side has a different intermediate shaft which used a female end shaft with integras and a male end shaft for si's.
Re: Are ITR driveshafts compatible with Si??? (Jwbetley)
the shaft i have bought is for a UK car right hand drive and its your drivers side one (the longest shaft), i have got the complete shaft. Would it fit?? looks the same from what i can remember but unsure about dimensions.
I know that all LHD B-Series are interchangeable, but RHD, I am not so sure. Bump for you.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supaman111 »</TD></TR><TR><TD CLASS="quote">the shaft i have bought is for a UK car right hand drive and its your drivers side one (the longest shaft),
Ours are both the same length due to the intermediate shaft.
i am gona try and bang it in tonight, fingers crossed that it fits, if not i will be getting a 15lb sledge hammer to it and winging it over the neighbours garden.
Mr. Badwrench
usdm itr axles will fit, BUT jdm splines are different and will not fit the hub. basically they are a civic inner with an accord/prelude outter.
Re: Are ITR driveshafts compatible with Si??? (boostedcivicsir)
i see, i think i should be ok then as it came off a UKDM ITR car which is very similar to USDM
Re: Are ITR driveshafts compatible with Si??? (nighttrain33)
no all b series axles (not driveshafts) are not interchangable.. assuming that your b16 tranny is LSD, then your axles may fit, but i doubt it still if they are LHD??????
