Help Yes or No or Your Sentence (Sensor)
Cigarette Squad
I got headers without o2 sensor,
should i buy a cat converter that Utilizes factory O2 sensor position
or do i still need one to be welded in?
Re: Help Yes or No or Your Sentence (Hatchback of Notre Dame)
however you set up your exhaust, you need your o2 in there somewhere. A good exhaust shop can weld in an o2 bung very cheap. IMO, unless you are turbo, get a high flow cat, you won't gain anything noticable with a test pipe while NA.
Cigarette Squad
Re: Help Yes or No or Your Sentence (IHateJDM)
ok i called in they charge around 20-30 dollars, when i ebay cat cost around 27 dollars... which is a better buy?
Re: Help Yes or No or Your Sentence (JDM_EG*)
a $27 ebay cat is not a real cat. its a resonator. Look for brand names on ebay for cats. I got a magnaflow hi-flow off ebay a while back for about $50 shipped.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EG* »</TD></TR><TR><TD CLASS="quote">also would the o2 sensor fit all the way down their</TD></TR></TABLE>
not all cats come with the o2 bung in it, you may still have to add it. That all depends on the cat, so you may still be better off just going to an exhaust shop. $20-$30 is about right at the exhaust shop. You can't really get anything done cheaper than that.
The best place for the primary O2 is within a few inches of the final merge in the header.
you can technically put it in the cat if there is a bung for it before the cat material.
if the bung is after the cat material you will run super rich at all times and may throw a CEL.
Re: (Relic1)
Just do what he said and go to an exhaust shop. You shouldn't have any problems after that.. make sure when you extend your wires that you do a nice job to prevent a CEL from popping up someday.
redciviclx14
10
07-08-2003 07:39 PM
GMan_CRX
06-18-2003 12:35 PM
