Rebuilding suspension in a 92 Si... what parts should be replaced?
Ok... I have a way to get parts from Advance at a discount, but only once, so I'm trying to figure out everything that I'll need to fix my car before hand. I know some of the items I'm planning on replacing anyway, but if anyone can make some suggestions, I'd appreciate it.
Here's the specs: 1992 Honda Civic Si, D16Z6, Eibach Pro-Kit springs, ~245,000 miles on the chassis
I know I'm going to be getting:
axles
upper ball joints
lower ball joints
outer tie rod ends
wheel bearings
brake rotors
brake pads
If anyone has suggestions as to what else I should replace while I'm at it, I'd appreciate hearing about it. I have the tools to do pretty much everything I need in house, so that shouldn't be a problem. I need to buy everything at once for this, so anything you think might be bad, please let me know, b/c I'd rather be safe than sorry.
Let the suggestions begin
axles
upper ball joints
lower ball joints
outer tie rod ends
wheel bearings
brake rotors
brake pads
Re: Rebuilding suspension in a 92 Si... what parts should be replaced? (qat727)
Given the mileage, you probably already changed your shocks. Maybe change your suspension bushings too.
Re: Rebuilding suspension in a 92 Si... what parts should be replaced? (RTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTI »</TD></TR><TR><TD CLASS="quote">Given the mileage, you probably already changed your shocks. Maybe change your suspension bushings too.</TD></TR></TABLE>
Actually, shocks haven't been changed yet. They looked stock when I pulled them, so perhaps they ought to get changed as well. Which bushings do you figure need to be changed? All of them?
Also thought I might get parts to rebuild the extra D16Z6 and trans I have around.
Re: (riceburnerryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan »</TD></TR><TR><TD CLASS="quote">i think energy suspension makes a master bushing set and its about 200 i wanna say? correct me if im wrong, and also i agree on changing the shocks</TD></TR></TABLE>
Shocks I can agree with. This car is my daily driver, and the only mods I'm making to it are to make it more comfortable and safer/more responsive. I'm not aiming for a race car here, and I'm not keen on giving up what's left of the ride I have.
I went by Advance today, and they have either Monroe Sensatrac, KYB adjustable (first born child price), and KYB regular shocks. Any recommendations as to which would be best?
Regarding the energy bushings, I don't think they're available through Advance, which kinda defeats the purpose of getting the discount on the parts. Beyond that, I have heard that the ride quality noticably lessened. Is this not the case? Do you think I ought to bit and piece it, and replace the bushings anyway?
Re: (EJ7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ7 »</TD></TR><TR><TD CLASS="quote">Go with AGX(adjustable), then you can set them to accomodate your ideal comfort/driving capable standards. </TD></TR></TABLE>
is it worth the extra $60 a shock?
plotomatic
Suspension & Brakes
10
09-19-2016 04:28 PM
redm3turbo
08-02-2015 08:09 PM
em1psyco
09-12-2012 01:50 AM
