stock bore size for d16z6 and d16y7
Does anyone know the stock bore size for these two engines.
I just bought a comtec headgasket that is 75.5mm and the place that I bought this from swears that it is for the stock bore of these two engines...
any info is appreciated.
tyia
tyia
Re: stock bore size for d16z6 and d16y7 (Civicse)
it.s 75mm, 75.5 is .020 over for pistons. you either have to have your block machined, get piston and rings, or ditch the gasket.
Mr. Fuch-yu
Re: stock bore size for d16z6 and d16y7 (Eyal 951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eyal 951 »</TD></TR><TR><TD CLASS="quote">it.s 75mm, 75.5 is .020 over for pistons. you either have to have your block machined, get piston and rings, or ditch the gasket.</TD></TR></TABLE>Yeah. and I don't think that you want to go through all that work just to keep from getting another head gasket.
-Red
-Red
It is weird that you can't get a Cometic Headgasket in 75mm... Go to the site. I says that the proper HG is 75.5mm.
What a sham.
http://www.cometic.com/catalogs/AutoCat04.pdf
What a sham.
Re: stock bore size for d16z6 and d16y7 (1.6t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6t »</TD></TR><TR><TD CLASS="quote">It is weird that you can't get a Cometic Headgasket in 75mm... Go to the site. I says that the proper HG is 75.5mm.
What a sham.
http://www.cometic.com/catalogs/AutoCat04.pdf</TD></TR></TABLE>
Running that gasket on your "stock bore" block should not cause any problems. Call them and ask them.
What a sham.
