clutch master and slave cylinder questions
i am installing a new type r trans this weekend and was curious if there are stock replacement clutch master and slave cylinders that are bigger than the ones that came stock on my 93 si?
I am a (Trial User) Army
Re: clutch master and slave cylinder questions (96ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96ls »</TD></TR><TR><TD CLASS="quote">i am installing a new type r trans this weekend and was curious if there are stock replacement clutch master and slave cylinders that are bigger than the ones that came stock on my 93 si?</TD></TR></TABLE>
Civic and Integra ones are both 5/8ths but I recently heard that Prelude MC's are bigger and might work. Look into that..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96ls »</TD></TR><TR><TD CLASS="quote">are the slave cylinders the same from civic to integras</TD></TR></TABLE>The correct question would be if B or D slave cylinders have a different bore. Not sure of the answer, hell, I don't even know if you can use a D slave on a B tranny or vice versa. I'm guessing no.
Re: clutch master and slave cylinder questions (litterbox)
thanks for the help!
and to answer your question the d series slaves will bolt up and work on a b series trans
MoogieBoogie
17
08-12-2013 11:53 AM
ZenDynasty
24
06-01-2008 07:56 PM
