Steering wheel shaking while braking..
1 Post
I'm now faced with another problem.. Steering wheel shakes when I brake, only at high speeds though, once i get down to like 30'ish the shimmering stops... I've changed wheel bearings, tie rods, brakes, now only thing i'm left thinking it might be is a warped rotor... What else may cause this..?? I was thinking maybe air in the brake lines, but it feels like im hitting tons of little speed bumps while its shaking an i didnt think air in lines would cause that much of a disturbance... Feedback plz..
Re: Steering wheel shaking while braking.. (cibola)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cibola »</TD></TR><TR><TD CLASS="quote">Replace or turn your rotors. They are warped.</TD></TR></TABLE>
Most likely.
Most likely.
Re: Steering wheel shaking while braking.. (JDM_SOHC)
Yeah rotors! Don't turn them, just get new ones!
PS the Chriogencally Frozen (SP?) rotors resist warpage. I think Power slot makes some.
lulz
Re: Steering wheel shaking while braking.. (saleensolution)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saleensolution »</TD></TR><TR><TD CLASS="quote">time for some rotors </TD></TR></TABLE>
yep yep yep
yep yep yep
1 Post
Re: Steering wheel shaking while braking.. (92'BluV-tecHatch)
yo i just bought new rotors couple months back.. maybe like 2-3 months ago... think theres a chance i bought'm warped..?? i've heard of that before thats y i ask..
you could have loose tie rods or other suspension or steering parts. that will cause vibration while braking, as well as clunking while going over uneven surface.
do you have power steering? steering rack could need to be rebuilt as well.
you can also try to tighten up the steering gearbox. its the big locknut thingy at the pinion, loosen that, and tighten the 12mm nut to spec. (not all the way)
but in general, you can have loose suspension, and then its kind of a chicken or the egg situation in relation to warped rotors, as to loose suspension causing your rotors to warp must faster, and vibration due to warped rotors causing your suspension to become loose....
replacing the rotors with new ones might alleviate the situation, but it may not fix the problem. seeing that you just replaced em 2-3 months ago... its a good guess that warped rotors might be the symptom and not the problem.
Re: (The_Shocker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC »</TD></TR><TR><TD CLASS="quote">yo i just bought new rotors couple months back.. maybe like 2-3 months ago... think theres a chance i bought'm warped..?? i've heard of that before thats y i ask..</TD></TR></TABLE>
my dad has had this happen on 2 impalas from the factory. first day and these symptoms. so i guess its possible yours are already warped
(these are company cars, he hated the **** out of them, he did not get a impala by choice)
1 Post
Re: Steering wheel shaking while braking.. (Tyson)
well see my whole suspension was shaking before so i replaced my tie rods an wheel bearings.. checked rack an pinion an **** an it all seems fine.. but while my car was in those suspensional ordeals u think it could have warped my rotors then..??
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">you could have loose tie rods or other suspension or steering parts. that will cause vibration while braking, as well as clunking while going over uneven surface.
OP sorry don't mean to jack your thread.
can you go into a little more detail. my rears make this noise. the only thing i've done is a rear disc conversion. my shocks haven't blown yet. h&r race on stocks
baaao
Acura TL, RL & ZDX
11
11-13-2008 02:03 PM
JDM_rolex
18
10-07-2007 08:30 AM
..::91TEG-G2::..
08-12-2003 03:25 PM
