squzzing noise from right left.. timing belt?? or tranny?
well usually when its cold, my car makes a squezzing sound from under the hood and didnt really figure out where exactly coming though, but tonight i drove and i take parkway and i hear squezzing sound whenever i release the clutch to neatural... i have to rev it up, in order to make it go away and when i put it in a gear and release the gera again it will come back.. it sounds like a god damn belt rubbing off metal or something.... i cant tell if its timing belt.. helpE!!
Re: squzzing noise from right left.. timing belt?? or tranny? (kihun_cha)
Could be your alternator belt. When it rained mine would squeal all the time, but also it would always do it at start up. Check and see if its worn.
I'm guessing at what squezzing sounds like, but mine makes a similar (again I'm guessing) noise when I release the clutch into neutral, a friend who is a toyota tech said its probably a broken clutch spring, but that if it works normally don't worry about it
Re: (ccjustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccjustin »</TD></TR><TR><TD CLASS="quote">if its only when you move the clutch, like push it in and out, it could be the release fork squeeking (with a k)</TD></TR></TABLE>
mine does that all the time. haven't figured out if it's that or the throwout bearing.
solution for belt squeaking: if your serpentine belt squeaks, get some belt dressing from THE ZONE (autozone). stuff works great, but i have to apply it every month or so. doesn't take more than a second anyway, really not a big deal.
if it gets worse/happens all the time (and isn't your belt), get your tranny inspected, or inspect it yourself (edumicate yourself - http://www.howstuffworks.com great site )
check power steering fluid lvls...
if not
check under timing cover/seperator disc rubbing<-- altenator/AC/timing belt rubbing.
>start your car
>open the hood
>remove the cam cover and look down with a light.
>look ontop of ur intake maniford
>locate the throttle body
>push on the lever n give the car some juice
>do this inside a garage or near some barriers
>this way you can use accoustics to pin point the noise
>if you can find whats wrong... post more info.. u were kinda vauge
I have rebuilt b16a/a2 d16z d15b7... i might be able to help
if not
>start your car
>open the hood
man
i have a squzzing noise coming from the driver side all the time and i can't find out what it is can some one help me plz
i also get this high pitch squzzing noise when i take a tight turn coming from the driver side too
and i have 97 civic ex
plz help me
plz help me
