cracked header by o2, bogging.....anybody help?
alright, dont laugh, i have a d15b7 in my hatch, the header is cracked right by the top o2....the car bogs really badly between about 1700 and 2000 rpm....could it be the header or do i have to get new o2? car has about 76k on it.
Re: cracked header by o2, bogging.....anybody help? (spoonracer84eg)
alright, thanks for the reply, didn't think that it was a problem, just checking though, guess i should try and torch the o2...or open up the wallet and get a new one...
Re: cracked header by o2, bogging.....anybody help? (codyb13)
Sounds like a sticking EGR valve...does it only bog and buck while cruising, or does it to it at WOT also?
Unceasing Measure
Re: cracked header by o2, bogging.....anybody help? (anony95ex)
If the car isn't throwing a code for an O2 sensor, then it's probably not an O2 sensor issue. Check your FITV and IACV and get back to us. Bogging in low RPM like that is usually ignition related - read: coil. Do some searches and cross reference the symptoms.
Re: cracked header by o2, bogging.....anybody help? (Archidictus)
it doenst bog when im cruising, and it is throwing a code, but i cant find the stupid harness to put the paper clip in, it only bogs when i starting out in 1st between like 1600rpm, and 2000rpm, and then if i get on it though, when i shift into second, i can feel it kind of bogging a little bit, until about 4000rpm-4500rpm.
one_shot
05-07-2007 11:39 AM
YEE*MagicEK20kombobomber
02-29-2004 08:04 PM
spencedogg
07-07-2003 07:35 PM
Black R
02-12-2002 04:38 PM
