What to do after perchasing ITR cams?
I've just purchased the 00' ITR cams for my B16 motor (00'si) for dirt cheap and have a couple of questions - The car has 90K miles on it, I'm looking to push my standard power upto 170whp (~200bhp), so i'm NOT looking for anything too aggressive. I've got the standard bolt-on ex/hd/cai setup. Daily driver so durability, low maintenance, and cost effective are what im going for as well.
1. Considering 90k miles on the motor, will upgrading the valvetrain be neccessary right now? Or can i get away with just fitting ITR valve springs and leaving the stock retainers?
2. Will an OEM Honda timing belt do for my application? (i'll be fitting some aftermarket adjaustable cam gears too).
3. Will an OEM Honda head gasket set do for my application?
Also, would it be wise for me to purchase cam gears for my CTR cam or can i adjust them using my stock B16a2 gears? I read that for mild cams, it may be pointless as you end up just moving the power band around.
Any suggestions you can add to help me out will be very nice. I have a 800 dollars budget on top of it all.
Re: What to do after perchasing ITR cams? (klomast3r)
Just install them and have fun.
At 90k just make sure the timing belt etc.. is ok I dont htink you have to change that until 115k?..
if your going to install Type R valve springs that would help but it is not neccessary.
Re: What to do after perchasing ITR cams? (SkAnK_aSS_BRyAn)
do the timing belt just to be safe.... its bette rto know its done then wonder if it will hold...while your doin that might as well do the water pump too...
nice responses back and quick too. thanks guys.
Oh, 1 more thing, if after putting the cams in and getting it tuned right. What about smog time? again im just trying to play safe, any suggestions.
Re: (klomast3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klomast3r »</TD></TR><TR><TD CLASS="quote">nice responses back and quick too. thanks guys.
Oh, 1 more thing, if after putting the cams in and getting it tuned right. What about smog time? again im just trying to play safe, any suggestions.</TD></TR></TABLE>
it should pass with flying colors
Re: (klomast3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klomast3r »</TD></TR><TR><TD CLASS="quote">flying colors?</TD></TR></TABLE>
Yes it should pass without any trouble. They are stock cams. and are not that much more aggressive then stock b16s
Re: (curioso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by curioso »</TD></TR><TR><TD CLASS="quote">u wont have any trouble man ull pass</TD></TR></TABLE>
Re: (Hello tom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hello tom »</TD></TR><TR><TD CLASS="quote">shove them up the pooper </TD></TR></TABLE>
Re: (windpar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by windpar »</TD></TR><TR><TD CLASS="quote">like you have a better idea?</TD></TR></TABLE>
He can shove it up your pooper...
I understand i wont' pass without any troubles if just putting the cams in, what about if i decided to up the valvetrain later on and add CTR pistons as well with tuning. Will that effect smog or should I be OK. Thanks again.
Guest
Posts: n/a
Re: (klomast3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkAnK_aSS_BRyAn »</TD></TR><TR><TD CLASS="quote">if your going to install Type R valve springs that would help but it is not neccessary.</TD></TR></TABLE>
Put your intake springs on the exhaust side and buy new type r intake springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no_boost »</TD></TR><TR><TD CLASS="quote">do the timing belt just to be safe.... its bette rto know its done then wonder if it will hold...while your doin that might as well do the water pump too...</TD></TR></TABLE>
Get some adjustable cam gears. Leave em at 0
Good Luck
Good Luck
Re: (klomast3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klomast3r »</TD></TR><TR><TD CLASS="quote">Will it be wise to get a good aftermarket timing belt or stick with honda?</TD></TR></TABLE>
Stock belt will be fine.
Re: (E.Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda »</TD></TR><TR><TD CLASS="quote">
Stock belt will be fine.</TD></TR></TABLE>
Arent you the guy with the purple engine?
Re: (SkAnK_aSS_BRyAn)
Arent you the guy with the purple engine?</TD></TR></TABLE>
I have a black engine.
boostedbseries2000
01-02-2005 04:21 AM
