CRV A/c Bracket, B18C Swap
Okay I did a search and still kinda stuck I know the bracket will work for a JDM B18c into a ek but wat I'm still stuck on do I still need the crv 97 tensioner pulley, if someone can lead me in the right direction. Also what else would I need for the bracket to work, if you can include the part numbers for the extra parts I need that would be great. Sorry about the double post wasn't for sure if it would best fit in here.
The p7j crv bracket will work fine
All the tensioners for b series have the same part number (arms are different, but its not a factor).
The only problem with this bracket is, apparently, you cant use power steering with it (why, I dont know...Id like to see). If you dont have it/dont care, it will save you money, since the p7j is 1/2 the price of the p54 del sol bracket
Re: (pdiggitydogg)
I thought if it was a b18c or b16b the deck height would make it able for to use the crv mount and still keep powersteering cause I'm keeping both ps and ac
Hapa88
12-19-2004 08:12 AM
