cel code 7 Throttle position sensor...does it affect VTEC at all????!?!!?
Old Dec 1, 2005 | 09:13 PM
akteamster's Avatar
Default cel code 7 Throttle position sensor...does it affect VTEC at all????!?!!?
i need to know if a cel code 7 will affect vtec in anyway?
perhaps not let it kick in at all? or make the car lag in performance...
please anyone with first hand experience help me.
i need a definate answer.
i dont think vtec is kicking in and the only codes i have are a 1 (primary o2), and 7 (TPS).
ive already confirmed that a code 1 wont prevent vtec from activating.
any input please!
Old Dec 1, 2005 | 09:29 PM
akteamster's Avatar
Default Re: cel code 7 Throttle position sensor...does it affect VTEC at all????!?!!? (akteamster)
bump i need to know asap
Old Dec 1, 2005 | 09:31 PM
Luserkid's Avatar
Your car should be running like **** being in limp mode and all.
Old Dec 1, 2005 | 09:39 PM
akteamster's Avatar
Default Re: cel code 7 Throttle position sensor...does it affect VTEC at all????!?!!? (Luserkid)
nope not in limp mode....runs normal but i just dont have vtec kicking in.
Old Dec 1, 2005 | 11:17 PM
akteamster's Avatar
bump for some answers !
Old Dec 1, 2005 | 11:19 PM
my_slow_civic's Avatar
Fix the TPS and find out.
While I dont know for sure, I am going to say it should not affect vtec. You need a speed signal, coolant temp signal, oil psi signal, and rpm signal for vtec to engage. The tps does not deal with either of those.
Old Dec 1, 2005 | 11:42 PM
akteamster's Avatar
Default Re: cel code 7 Throttle position sensor...does it affect VTEC at all????!?!!? (my_slow_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic &raquo;</TD></TR><TR><TD CLASS="quote">Fix the TPS and find out.
While I dont know for sure, I am going to say it should not affect vtec. You need a speed signal, coolant temp signal, oil psi signal, and rpm signal for vtec to engage. The tps does not deal with either of those. </TD></TR></TABLE>
its 4 in the morning so i cant go fix it right now to find out.
im asking becuase i neglected that code thinking it wouldnt effect vtec....but now that i have tried everything else since that is the only major code my motor is throwing im trying to link it to that.
i dont see why else it wouldnt be engaging
Old Dec 2, 2005 | 09:19 AM
93accordNOS's Avatar
I know the AEM EMS uses Coolant Temp, Load, RPM, TPS, and VSS, as parameters for VTEC. The stock ecu should use all these parameters also, so yes without TPS you're also without VTEC.
FASTESTCB7inQNZ
Nov 18, 2009 06:41 AM
ghettoSi
Jan 11, 2008 11:39 PM
cates_07
13
Feb 20, 2006 08:25 AM
ninety9ex
Jan 26, 2004 07:40 PM
Hondasaurs
Apr 25, 2003 07:30 PM
