So I picked up a '00 Civic Ex Coupe & wanted to upgrade the radio....
But now my A/C - Heat will only work on MAX. WTF, the car runs fine, & the radio works great. Even if I turn it down just a bit, it basically turns off?
Anyone have any ideas?
Yes I already searched.
Modified by beandip at 4:53 PM 12/2/2005
Location: With my POS D15B2, Whereever whenever, United States
Re: So I picked up a '00 Civic Ex Coupe & wanted to upgrade the radio.... (beandip)
bad motor
happens quite frequently
Re: So I picked up a '00 Civic Ex Coupe & wanted to upgrade the radio.... (MugenHonda)
??? Um No.
The A/C Heater was working perfectly fine before I put the Radio in. It still works, but only on MAX A/C, nothing lower.
Re: So I picked up a '00 Civic Ex Coupe & wanted to upgrade the radio.... (Karizmah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Karizmah »</TD></TR><TR><TD CLASS="quote">Isn't there a fuse for the lower setting on the fan?
Did you check it yet?</TD></TR></TABLE>
Check the fuse, make sure you didn't unplug anything on the controls for the HVAC.
Generally speaking though, when you only have high and off, the cause is a bad blower resistor. Could be a coincidence.
Re: So I picked up a '00 Civic Ex Coupe & wanted to upgrade the radio.... (anony95ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anony95ex »</TD></TR><TR><TD CLASS="quote">Check the fuse, make sure you didn't unplug anything on the controls for the HVAC.
Generally speaking though, when you only have high and off, the cause is a bad blower resistor. Could be a coincidence.</TD></TR></TABLE>
yea, well my mom's car 99 alero... here air conditioning and heat would only work at 4-6 settings or w/e, I search around turned out to be blower motor resistor.. bought a new one at gm for like 30 bucks and fixied... hardest thing ever to install
Well, I ripped apart the dash again & replugged the cable back in. Perfect.
Even though the thing was plugged, & had to replug it. Go figure. It works.
Thx for the help
Thx for the help
immajackuup
13
05-10-2008 07:34 AM
doggworld1233
06-17-2006 04:32 PM
Audio28
Audio / Security / Video
08-27-2004 05:36 PM
