? about GSR brake swap on a EK
Location: City of fakeJDMs but their vT3s HiT H3ll4 L0uD...., usa
Just like the title says ... will the GSR brake swap work for a EK ... will i need any additional parts or would i have to make changes or stuff... any info will help thanks
Re: ? about GSR brake swap on a EK (Bone Stock)
Everything bolts right up. The only thing you don't need is the rear lca's. You don't really need the brake booster or master cylinder but if you get them along with the swap then you should install them as well.
Which ek do you have? If it's a cx you will need more than say if you had an ex.
Bassically you should get the discs assy, the trailing arms,
proportioning valve(unless you have an ex or si)
also the master cyl/brake booster.
you'll also need to get si e-brake cables.
Re: ? about GSR brake swap on a EK (tommyj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommyj »</TD></TR><TR><TD CLASS="quote">i recommend stainless steel brake lines too</TD></TR></TABLE>
Yes, they work great!
Re: ? about GSR brake swap on a EK (EL Vap133)
I'm just posting this for my friend since he doesn't have an account. O' sorry it's an CX and yes his going to use stainless steel brake lines too.
So he should just use the stock upper arms for the fronts, and the rear LCAs. Would he need anything else?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Just use your stock upper arms for the fronts, and your rear LCAs for the rears. </TD></TR></TABLE>
I used my stock rear lca's and they fit as well.
-Shane
-Shane
Re: ? about GSR brake swap on a EK (nighttrain33)
It is easier to just do the lca's with the rest of the set-up, unless the bolts are a pita. I did the swap with the GSR lca's, but the GSR's were bent, so I swapped mine back on, and it bolted up just fine.
-Shane
-Shane
Romo Pyro
21
01-19-2010 06:13 PM
enrique
07-21-2003 11:22 AM
