B16 swap into 94 hatch, all parts needed,, still won't start?????
I swapped a B16a old school motor into my 94 hatch, changed everything to run obd1 and engine turns over, its getting gas, but wont start.. What should I do????
Im running a P28 ecu.
Re: B16 swap into 94 hatch, all parts needed,, still won't start????? (krispycrutons)
how's the timing. what ecu are you running. list as much info as possible pleaseeeeeee
Re: B16 swap into 94 hatch, all parts needed,, still won't start????? (ADVAN EG2)
Im running a p28 I dont know how the timming is cause unable to start.. I just replaced the distributor, I thought that couldhave been the problem..
Just looked, and there no spark,, you think the plugs on the wires are bad? probly Im gonna change the spark plugs, i dont have new distributor wires
if you are swapping it into an EG(92-95) the only thing you should to wire is your vtec ... everything else should be there and if you are running a stock p28... thats for a sohc d series motor... the only way that ecu would work is if it's chipped. Lemme know what kinda car and everything and i will be able to help you better. And if it's an EK(anything newer) and you converted it from obd2 to obd1 then it may be a problem with your wireing.
honda305
09-10-2010 07:30 AM
JDMb18c1HATCH
07-03-2010 07:26 PM
