I need someone to check their EG for me...
I'm in the middle of a swap right now and would greatly appreciate it if someone could check something for me in the engine bay of their EG. I don't even know what its called, but is a 4" horizontal cylinder on the back of the intake manifold. It has 2 vacuum tubes on it and 1 round 2 wire electrical plug. Could you tell me what colors the wires are on the plug?
Re: I need someone to check their EG for me... (transpar_nt)
it's called the IACV, idle air control valve, has two hoses connected at the bottom of the unit w/ a plug for the switch
Re: I need someone to check their EG for me... (damnraz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damnraz »</TD></TR><TR><TD CLASS="quote">it's called the IACV, idle air control unit, has two hoses connected at the bottom of the unit w/ a plug for the switch</TD></TR></TABLE>
Damn, so that's what the IACV is.
Green and black/yellow you say? Thankyou both!
Imperious: Mod of Valor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt »</TD></TR><TR><TD CLASS="quote">Damn, so that's what the IACV is.
No worries, I was lost on it at first too.
Okay, I've got the wiring harness all connected and everything is ready to go except for one plug. It is a round, grey connector identical to the one that plugs into the IACV, except the wires are red, and yellow with a black stripe. It is directly under the intake manifold, but I can't for the life of me find any more open plugs!! (EG's harness onto a b18b1.) I looked back on the d15 but can't find a place for it there either which doesn't make any sense because I just took it off of there an hour ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt »</TD></TR><TR><TD CLASS="quote">Okay, I've got the wiring harness all connected and everything is ready to go except for one plug. It is a round, grey connector identical to the one that plugs into the IACV, except the wires are red, and yellow with a black stripe. It is directly under the intake manifold, but I can't for the life of me find any more open plugs!! (EG's harness onto a b18b1.) I looked back on the d15 but can't find a place for it there either which doesn't make any sense because I just took it off of there an hour ago.</TD></TR></TABLE>
Maybe the purge control solenoid valve connector? I don't remember the wire number/colors of that plug but it can be easy to overlook and should be in the same general area.
Re: I need someone to check their EG for me... (xavenged7x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xavenged7x »</TD></TR><TR><TD CLASS="quote">Maybe the purge control solenoid valve connector? I don't remember the wire number/colors of that plug but it can be easy to overlook and should be in the same general area.</TD></TR></TABLE>
Cancel what I said last. There are actually 2 plugs that I can't find a home to. There is seriously NOTHING. I don't know how this can even happen. I can't find the plugs on the d15 either. expletive this is frustrating...
B_Swapped93
03-08-2017 03:05 AM
