Brake Rotor Screws..Need help ASAP.
The picture below has two screws circled. What happens when one falls off?
or do those hold in? what is the purpose of those screws?
On one of my rotors one is missing? would it cause any issues? and weird noises?
Re: Brake Rotor Screws..Need help ASAP. (Hatchy-Ownzjo0)
Anyone know the size of that screw? so I can go get one?
but what problems would I be runing into not putting that screw in?. I just want to know all the consequences not putting that screw in.
I dont want to know that it just important to have it kinda want to have an explaination
Re: Brake Rotor Screws..Need help ASAP. (dek1mfk)
those are for when they put it on at the factory, so the rotors didnt fall of the car. Drill those bitches out you dont need them unless ur **** about your work on ur car. If so, u'll need a impact hammer. They're a bitch if your car is older, so i'd just drill them out....good luck!
Re: Brake Rotor Screws..Need help ASAP. (deadend9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dek1mfk »</TD></TR><TR><TD CLASS="quote">u dont need it i have been drivin mine for months with out them, it gets held on by the tire</TD></TR></TABLE>
don't need them.....<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadend9009 »</TD></TR><TR><TD CLASS="quote">those are for when they put it on at the factory, so the rotors didnt fall of the car. Drill those bitches out you dont need them unless ur **** about your work on ur car. If so, u'll need a impact hammer. They're a bitch if your car is older, so i'd just drill them out....good luck!</TD></TR></TABLE>
Darth ModerVader
As others have stated, the screws are completely unnecessary. In fact, many people choose to leave them off when replacing the rotors, since they have a tendency to become stuck and difficult to remove. Anyone telling you that you need the screws simply has no idea what he or she is talking about.
1 Post
Re: Brake Rotor Screws..Need help ASAP. (Project_DX)
been drivin both of my hondas, after i first replaced the brakes never put em back on cuz no matter what theyre a beotch. leave em off youll be fine
these screws are there mainly just to make sure the rotors dont fall off on someones head at the assembly line. I actually bought some wagner rotors from oreillys for the front and they came without holes for these screws. so i dont have these screws anywhere on the front of my car.
WHen you think about it, how could they affect anything cuz when you torque down your lug nuts it holds everything flat right?
Re: Brake Rotor Screws..Need help ASAP. (SkAnK_aSS_BRyAn)
They are there for a reason, but it won't be a huge deal if not. They are like .03 cents so you should just get new ones.
Darth ModerVader
Re: Brake Rotor Screws..Need help ASAP. (B_Something)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B_Something »</TD></TR><TR><TD CLASS="quote">They are there for a reason, but it won't be a huge deal if not. They are like .03 cents so you should just get new ones.</TD></TR></TABLE>
Yes, they are there for a reason, but that reason has nothing to do with the end user of the vehicle. Once the car leaves the assembly line, they no longer serve a purpose.
Re: Brake Rotor Screws..Need help ASAP. (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Yes, they are there for a reason, but that reason has nothing to do with the end user of the vehicle. Once the car leaves the assembly line, they no longer serve a purpose. </TD></TR></TABLE>
^^^Yep, I have worked on pontiac brakes and when you take the rim/wheel and the caliper off, the rotors can be pulled off. The wheel holds the rotor onto the hub
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B_Something »</TD></TR><TR><TD CLASS="quote">They are like .03 cents so you should just get new ones.</TD></TR></TABLE>
.03 cents? That would make em $0.0003. Dayam... that's like free!
Messin with ya
Messin with ya
1 Post
i dont see how one fell off, the usually require you to have to use power drill, or dremel it into a big flathead shape and do that
Re: Brake Rotor Screws..Need help ASAP. (sockvtec)
Well I left mine on so when I was replace the caliper bracked the rotor is solid and wont move around. I have an impact screwdriver so it makes it alot easier. If you have the right tools I would leave them on.
The screws aren't that important. So long as your lug nuts are on tight you won't have any problems. The screws sort of keep the rotor in place (especially when the wheel is off) and when the wheel is on the lug nuts do the job. Just go to the Honda dealsership and get a replacement, it'll cost cents.
if it makes you feel better, just get some at your local pick and pull or the dealer, they are free at the pick and pull and cheap at the dealer.
jdm95gsrteg
01-26-2012 05:11 AM
Rywire
10
01-12-2004 11:50 AM
