94-01 integra type r 4door rear seats into a 94 civic 4door
pretty much like it says...will 4door integra rear seats fit into a 94 4door civic??
Re: 94-01 integra type r 4door rear seats into a 94 civic 4door (projektvtec)
i have seen pictures of this mod done before even on japanese magazines. its not impossible but anyone can manage. sorry no pictures.
Not sure about the 4 dr, but I put Gsr leather in my 93 Civic coupe and what I had to do was use the 4 dr rear lower seat and 2 dr rear upper....I then took the gsr upper and had an upohlstery shop take the leather off the gsr foam and stretch it over the civic foam, adding a little to each side to compensate for integra's narrow rear seats.....as for a 4 dr I'm sure it's possible and probably easier than you think....the key is to take alot of measurements and see what exactly needs done...the rear lower seat is probably a bolt it and the only modding would be to the upper portion....Give it a shot though and post pix when you're done...Good Luck!!!
Yes the DB8 rear seats will fit fine. Ask Nelson aka Maxboost about it. You will be able to keep both the tops and bottoms on the 4dr since they are a bit wider.
It should fit well. I was about to put a teg coupe back seat in my 4D EG and found out through SEARCHING that the bottom was too short, so the 4D teg should make up for those couple inches. They do fit, so don't worry about that, the question is will it sit flush and not be too long or too short?
i did it and it is awesome, looks so good, fits perfictly, and if you want some pictures befor you get into it, ill post some.
95_GSR_SEDAN
08-24-2008 03:41 PM
jefe
08-23-2004 09:19 AM
lippage2004
03-22-2004 11:33 AM
