Everyone With Power Windows on DX/CX
freind just bought a car with a ghetto rigged power window set up, off an ex we belive. i saw another member post with the same problems but the thread wasnt talking much about it.
it worked at first and now it just rolls down half way and both are stuck like that.
-im pretty sure its off-track, but what else could be wrong?
-could it also be the motor rolling the windows up is bad?
-how hard is it to put it back on track? any tips, ideas?
TIA
Re: (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay »</TD></TR><TR><TD CLASS="quote">It's probably a bad window regulator.</TD></TR></TABLE>
How much are those and how do you know if its bad? I still haven't taken mine door panels to take a look yet untill this weekend.
1 Post
Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW »</TD></TR><TR><TD CLASS="quote">
How much are those and how do you know if its bad? I still haven't taken mine door panels to take a look yet untill this weekend.</TD></TR></TABLE>
wire them up directly to a 12v constant power and see if they go up and down with no problems
Location: Why so you can pretend like youre interested, FL/OK
Re: Everyone With Power Windows on DX/CX (character)
When you click the switch up, does the window slightly move or does NOTHING happen. Remove the door panel and take a look is going to be the easiest way to see what's going on.
Re: Everyone With Power Windows on DX/CX (INVALID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INVALID »</TD></TR><TR><TD CLASS="quote">When you click the switch up, does the window slightly move or does NOTHING happen. Remove the door panel and take a look is going to be the easiest way to see what's going on. </TD></TR></TABLE>
When I click the switch up when it's all the way down it goes up then gets off track and stuck. Same thing on both sides.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">wire them up directly to a 12v constant power and see if they go up and down with no problems</TD></TR></TABLE>
Alright I'll try it today or for sure t/m.
Re: (ekb16)
what should i look for? im new at this
where is that part? in the door?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">my car is a 98 cx hatch with power everythin and mine doesnt do that..mine works perfect</TD></TR></TABLE>
thanks for your help....
Re: (character)
Your window is probably off track. Remove the door panel and plastic, there will be some holes where you will be able to see the mounting bolts and white plastic tabs of the actual window that are there. Click the window up and down and see when at exatly which point it goes off track each time. Then look at the rubber lining on the sides of the window to make sure it isn't twisting or binding a little.
accomsrazor
01-11-2011 08:43 AM
