( code 14 wont go away.
i just bought a del sol and it drives good and all but it has code 14 ( idle air control ) ive took it off and cleaned it and put it back on but the code wont go away . ive reset the ecu many times , it just comes right back like ten sec after car starts.. when i first turn it on it idles at about 1.5 K rpms and it kinda bounces a lil almost like a sputtering but not too bad. but i know its cause of the idle control valve. i dunno why . thats the only code too. it drives normal and after a few min it idles normal but not when first started? even if i unplug the IAC it still does it which i dunno how. its the 1.5 single cam motor, i just need it to last for a few months till i do a swap but i want it to be right too.
Re: ( code 14 wont go away. (mwieczorek43)
ya, should i just hook the + to the + wire on IAC and - to any ground and check for voltage when car is on or how?
Re: ( code 14 wont go away. (97grnrs)
ooo please tell me how also my 98 ex dose the same thing and i did all what u did to ur del sol iac. so when u get how to do it pm me or sumithing to tell me. car wont pass inpection with it like that
thanks
thanks
Re: ( code 14 wont go away. (Archidictus)
here is the factory manual procedure for checking your iacv. do this first then go buy a new one if you have to. remember folks, you can find a lot of stuff if you search for it
https://honda-tech.com/zerothread?id=978376
hasty91ef
03-27-2012 08:50 AM
raverx3m
11
11-10-2011 06:24 AM
MWLW20
41
08-28-2009 04:45 PM
