does the obd1 d16z6 have a knock sensor?
Re: does the obd1 d16z6 have a knock sensor? (CRXified)
ok, thats why im getting a code 23 when the swap was done. does anyone know the pin on the gsr ecu that the knock sensor goes into. im going to try and wire one in today.
Re: does the obd1 d16z6 have a knock sensor? (strils)
thanks, but im going to have to wire a wire in there because we are using the d16z6 wiring harness that does not have that wire?
Re: (strils)
but how do you get it into the actual pin? the other ones are very hard to pull out (not that i have tried that hard but they are in there ggood!)
Re: (the.hamburglar)
if you look at the back of the plug you will see that there is a keeper at the top and bottom of the plug that clips to the side plastic. doesnt take much force but these will pop and fold up on the plug, then you have access to the pins and can pull them out with relative ease.
beginmyhonda
07-29-2009 02:14 PM
phanatic
05-18-2007 02:21 PM
hj
10-29-2003 04:40 PM
