D16 clutch and flywheel
1 Post
I have y8 head on a z6 with a y8 intake manifold. I am not sure which would be a good clutch for me. I would like to have something that grips a little more the stock. Flywheel I was thinking of getting a Fidanza. What are your thought?
Dave
Dave
Re: D16 clutch and flywheel (93SiVtec677)
i believe that exedy makes the stock clutches for honda, they also have a line of performance clutches. Advanced clutch technologies also makes good performance clutches.
does your clutch slip?? If not, then why waste money on a clutch that will easily hold what you are thrwoing at it. It took 15 psi, over a 100,000 miles to slip mine, and even then, i could easily control it slipping. Didn't happen until third or fourth gear.
You dont need a clutch with a lot of 'grip'. You aren't making any power.
If yours is bad, replace with with an Exedy OEM replacement. Can be found on ebay for <$80
1 Post
Re: D16 clutch and flywheel (coneheadsracing)
no its cause my clutch is not far from fininshed and since I have to replace it I would like to replace with something that grip at little more.
Dave
Dave
More specific? Head and Intake Manifold don't matter. Get the one for your block. If you're gonna go the OEM Exedy replacement. Theres are from 92-00 civics. (Except 99-00 Si). So pretty much for all D-Series. I personally purchased one on ebay for 72$ and I couldn't be happier.
rasinhell
01-29-2005 04:58 PM
vtec94civic
11
08-13-2004 05:56 PM
