!!!! idle prob > i did the coolant bypass!!!!!
ok i have the weird idle thing where when you stop at a light my idle goes up and down over and over. after trying everything this site has to offer i decided to do a coolant bypass(if u dont already know what it is look here: https://honda-tech.com/zerothread?id=1423187 ) ur basicly bypassing the coolant lines to the FITV,IACV,and the TPS. any help on what could cause the idle even after the bypass other than a vacuum leak would be great.
ps i did check for a vacuum leak
1 Post
Re: !!!! idle prob > i did the coolant bypass!!!!! (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned »</TD></TR><TR><TD CLASS="quote">thanks for the advice ,but maybe you can try and think of a way to help instead.
I just did, what do you learn if I just tell you what it is? Nothing. It would also be wise in the future to not treat one of the only REAL techs on this site with any disrespect.
Now what keeps idle constant?
1 Post
Re: (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned »</TD></TR><TR><TD CLASS="quote">tps,iacv yadda yadda</TD></TR></TABLE>
TPS wont cause this.
you may need to build a block off plate, that's what i am getting at, although your unit has no water running through it, it could still be adjusting the idle. Or it can have its adjustment stuck at a certain place.
It may not be your IACV at all, its kind of a hands on thing. You may just have to mess around and try different things, in fact, you will have to. Let us know, good luck
